RuudNL
For years I have been planning to build a stereo microphone with a rotatable microphone capsule.
The main reason I never realized this were the mechanical difficulties in doing this properly.
By coincidence I found a microphone that already meets most of my requirements:
- Affordable (Requirement number one!)
- Two double sided edge terminated microphone capsules
- Separate pattern selection per microphone system (Omni, figure-8, cardioid)
- 10 dB pad + low cut filter per microphone system
- Top capsule rotatable from 0 to 90 degrees
This microphone could be used for X-Y, M-S and Blumlein recordings.
The microphone uses a modified Schoeps circuit and a DC converter for the polarisation voltage.
Although I thought about modifying, the quality is adequate for my needs.
There are a few things that I have changed:
- The capsule polarisation voltage was about 40 volts, I have raised that to 50 volts.
- The wiring of the 5-pin XLR connector was a bit strange. (Is there even a standard for stereo microphones?)
The original connection was: Pin 1+2 microphone 1, pin 3 shield/'ground', pin 4+5 microphone 2.
Since another stereo microphone that I own has a different connection, I have changed this to: Pin 1 shield/'ground', pin 2+3 microphone 1, pin 4+5 microphone 2.
The only obvious improvement are the headbaskets.
These headbaskets are single layer mesh, but do not provide enough shielding for electrical fields.
I have added a second layer of mesh and now the hum and electrical interference is no longer a problem.
Maybe this microphone could be interesting for other members who are looking for something similar.
