JohnRoberts said:
Some lower voltage phantom supplies use less than the typical 6.81k build out resistors, but these still need to be well matched or tight tolerance parts, whatever value that is.
There's a DIN standard for P12V which specifies 2 x 680R
But 'true' P12V is very rare. I only know of some Sound Devices preamps that claim this and they use 6k8. Probably only vintage German broadcast gear does this 'properly'.
But there are a LOT of 'professional' preamps that have wonky P48V. My MOTU Traveler is P39V though I note it only claims 'Phantom' and has no spec. All da wonky P48V's have 2 x 6k8
_________________
http://groupdiy.com/index.php?topic=12807.0
mrkva, this is a good thread but the difference between that and your application is the word '
portable. If you are a true SMPS guru, you would still only get LESS efficiency & idle current than 5 x 9V PP3s. So you would probably still carry that pack of 5 x PP3s ;D
In Jurassic times, I designed & made a 12V to +/-15V switcher with 90% efficiency on full load and small idle current .. but it was a LOT of work including a custom wound ferrite transformer. Today, the knowledge & parts to do this are much more freely available ... but I would still buy a complete unit in a little shielded can with
guaranteed efficiency, idle current & noise spec. if I needed this for real.
The R&D to do a good one is not trivial .. for me, more than the effort to design a SOTA mike preamp.
The 5 x 9V PP3s, I can knock up in a morning with guaranteed efficiency bla bla .. from parts available even in Cooktown, rural Oz, at the edge of the known Universe. If your requirement is part of a complete mike preamp, I would power it from the 5 x 9V stack too.
But if this thread comes up with a simple design with uncritical layout, guaranteed efficiency bla bla, using only parts from Digikey & Mouser, I will be the first to congratulate you.
Note the design by moamps in that thread uses Unobtainium & only hints at efficiency bla bla
