[quote author="Kev"]
but my pots may be different to your pots and so we have a different situation already. [/quote]
Oh definitely, even 2 pots from the same manufacturers will not be the same due to its tolerance range. Which is the reason why the method works on averaging, the accuracy will depend on the number of measurments collected not precision of 1 particular unit.
Compressors and Mic-pres are all about gain structure and the battle between noise and clipping ... headroom
Relevance??? lost me there.
but you have to accept that what we are doing here is comparing and the whole point of dB's is to compare ... IN THE SAME STIUATION
db is nothing but a ratio or in reference to a figure, still it needs a measurement of some sort to calculate db. The SAME STIUATION here is the circuit, there is nothing to be gained by converting the measurment into db since we are not trying to compare different circuits (eg. La2a vs Pultec)
UNLESS
you can be sure these units are the same ( I don't think they will be)
They won't be too much different except for the tolerance of components used, since THE CIRCUIT IS THE SAME unless the individual decides to mod the circuit which the unit's measurment will not be used for averaging.
It is actually harder trying to different than being the same, since the circuit is the same; the part list is the same. The only thing that might be different is probably the face panel, knobs, meter, panel marking and in many occasions even that is the same.
a simple test like this is only a loose indication that you may have a major error somewhere
Not only that, you get an idea of the noise level based on the averaging method and it serves as a reference point of that circuit. Also, for someone that has a low noise measurment it would be a lead for invetigation to see what the person has done to the circuit to obtain that. It could be real beneficial to all the builders of the same unit, if such an improvement has been discovered.
It might be cool to get a signal of known level running throught it first and then compare the RMS values.
The reason I say this is that unless you have a True RMS Meter it is likely we will measure the same signal and get different results.
I have more than a few DMM's and they all give different result for the same signal ... even the one of the same make and model
yeah yeah
I shouldn't buy the el-cheapo meter
Well, that sounds like the accumulative effect of components tolerance range. Just out of curiosity, how much of a difference do you get?? In decimals?? Not the that it really matters, since it will all be averaged out anyway.
