thor.zmt
Yes you can. But, assuming some sort of balanced input, "we" don't do that because it's not the correct way to optimise the interconnection.
Pin 1 should go straight chassis. There is an AES paper / standard on this since IIRC more than 20 years
If you do this it is vital to not use Pin 1 as audio ground.
And no, Pin 1 to chassis is not a standard, nor is it a formal AES recommendation.
Correction, there does appears to be an AES recommendation, AES48-2005.
I still consider that ideally screen and audio ground are connected separately, HOWEVER, if the majority of equipment follows AES48-2005 and uses shielded single pair WITHOUT separate ground connection, following AES48-2005 is expedient.
Both AES48 and my own recommendation agree that the shield should be terminated directly to the chassis under all conditions and the connection between audio circuit (ground) and chassis should be at the star point.
Back to my original point and post.
I feel that while what is written in that paper is technically correct, given that XLR is actually a 4-pin system (Pin 1, Pin 2, Pin 3 and Shell - Pin 4) I hold the opinion that it is preferable to treat Pin 1 as audio ground and Pin 4 as screen.
If such a device is interconnected using a cable and second device following "pin 1 to chassis" (or with a cable that follows the "4-Wire system" but a second Pin 1 to chassis device) it remains fully compatible and will perform as well as possible in the context.
But improved performance (reduced noise sensitivity, improved resistance to EMI/RFI) is possible in a system that is completely build on the separation between signal ground and screen / chassis.
If there is any need to debate this (there really should not be any), I suggest we do in the thread I split off, to preserve SNR here:
Are there things that can be addressed in older circuits to modify them to deal better with the wireless routers and such?
Thor
