Morrow
Active member
I've discovered that my old SoundWorkshop Console's panning and bleed problems are actually the result of bad pots (I replaced the existing pots with Mil-Spec Clarostats on a channel and both problems went away).
Now I've got to replace the pots on all 20 channels and need brand / model advice.
Each channel needs:
-One Linear Taper 10K pot for panning, center detent would be great.
-One Audio Taper 10K pot for the output level (to the mixbuss).
Both are the typical 1/4" round shaft sizes with metal bodies.
I've read the other three threads on pots in general, and it seems like Alps, Bourns, Clarostat and Alpha Taiwan are good to go with. But, I'm having trouble figuring out exactly which Series of each of these people are commenting on.
For example, Bournes has a ton of different lines that they make, many of which seem to fit the size and specs that I'm looking for.
Does a metal or plastic body make a difference?
Can you guys recommend a model or two to at least try out? I don't have a ton of cash, so I was hoping to spend no more than a couple hundred dollars for all 40 pots.
Model numbers would be a great help!
Thanks everybody,
Chris
Each channel needs:
Thanks everybody,
Chris
