john12ax7
For some pots simply breaking off the tabs doesn't leave a flush mounting surface. Using through holes would be inexpensive but then is visible from the front. The best solution seems to be a machined blind cavity in the back of the faceplate, but this can add significant cost.
So what is the best cost effective solution for medium quantity faceplates, around 50 pcs.
