plastic or nylon? have not tried plastic,
when you drop the heated coils in the can, the air bubbles inside the windings will contract as the coil cools down, this creates a vacuum which pulls in the verathane,
if doing high voltage stuff, then you need to pull a good vacuum, but then you need a air tight tank that will not implode, a hose with a looking glass on the oil end, and a gauge to tell when the tank is full, otherwise the oil will get pulled into the vacuum pump, oil does not compress like air, so the piston tries to come up against that oil and you bend the crank shaft of the vacuum pump, sometimes this takes a few seconds for the cylinders to fill with oil, so when we heard that vacuum pump start knockin, we ran over there and shut it off,
this was usually after lunch time if you catch my drift, 8)
now when you pull a vacuum on a huge xfmr tank, something maybe 10 feet high by 12 feet square, like the twelve we made for the Fusion project for the Lawrence Liverpool Lab, then you have to make sure the tank is strong otherwise the roof of the building caves in due to all the air getting sucked out of the room in ten nano seconds when the side seams cave in,
they use whats called Kinney Oil for vacuum pumps, if you use regular oil, bad things can happen like maybe an explosion and if your lucky, an oil fire,
