leigh
As previously detailed here (and here), I was trying to refurbish the mic pres from an old Harman Kardon tube mini PA.
I've since decided to redo the whole audio path based on the original Hamptone project (Tape Op #30), keeping mostly just the chassis and the power supply.
The power supply was set up as a voltage doubler, which put out waaayy more voltage than I needed (500+ VDC unloaded). It looked like this circuit, taking the DC from the + and - (the "0" output was not used in this design):
I removed (not bypassed) D2, and as I'd hoped, this cut the voltage down to about 250 VDC.
Q: Is this now safe? Are the caps seeing too much action?
I understand this to be a half-wave rectified circuit, with heavy filtering. I just want to be sure that I'm not now overworking those caps.
Leigh
Leigh
