Hanfri, please check the pinout for the 7815 on the datasheet.JohnRoberts said:Stop press... For a 7815 to output more voltage than it's input is not reasonable. Either one of two things is going on,
A) Something externally is dumping current/voltage into that PS output.
B) Your measurement is not reflecting accurately what is going on. +18V on the unregulated input is marginally low. IIRC the basic 7815 had something like a 3V drop out so 18V is about the minimum to support 15V output, but this does not remotely explain an output higher than the input... You may have stumbled upon free energy, you can use to make a perpetual motion machine. 8) 8)
Then check it meticulously with your PCB. Draw up your circuit diagram and check each node for DC resistance to each expected component connection. Check off each node as you do this.
Then check DC resistance between the pins on the 7815 & the rectifier & capacitors on the transformer.
It looks like you have IN & OUT mixed up. This might have killed both 7815 & 7915.
