Im working on this DIY guitar amp, a 30W el34 thing.
The amp is finished and sounds good and im about to put it in an enclosure, when i came to think: i dont really know anything about tubes and heat-build up.
When i build SS-poweramps i can select an appropriate heatsink based on calculating with thermal R, but with tubes im kinda lost.
I had an idea about mounting the chassi at the bottom of a closed 2x12 speaker box about the size of a fender twin(maybe a little deeper). Tubes would be facing up.
But seeing as the box is sealed theres is nowhere for the heat to escape, and i wonder if this will shorten tube life?
Are there any calculations or rule of thumb for this kind of problem?
