Since the circuit draws less than 1W, I woud use the 1W version. A 3W converter must operate with a load that draws at least 0.5-0.6W for correct operation.No, I'm thinking of running off a DC wall wart.
Since the circuit draws less than W, I woud use the 1W version. A 3W concerter must operate with a load that draw at least 0.5-0.6W for correct operation.
So take a few minutes and think about what you really need. Do you need input and or output level controls? Is that going to require any additional buffering? You started out with a simple unbalanced circuit, and now have balanced input and output buffers. Most unbalanced gear uses different operating levels that balanced gear. Have you considered what you want your default input and output nominal levels and headroom to be? Where in that nominal input/output range do you want noticeable colouration/distortion to kick in? Do you want to control that strictly with the send levels of the upstream device and the input attenuation/make-up gain on the downstream device? Or do you want a gain control before and after the colour circuit so you can control the distortion level independent of the operating audio levels (kind of like the gain and master volume controls on a guitar amp)?
the device would be more usable if it had Gain
and Master controls
Since you'll be playing with the level diagram, you'll need some kind of level indicator, whether it is a simple LED or a full meter is amatter of choice.I've been thinking about this a bit more and I can see that your advice is right - the device would be more usable if it had Gain and Master controls. What would be the best way to add these?
While you're at it, why not add a High Pass filter, a 4-band EQ and a compressor?Also, I've been thinking about adding a Dry/Wet control too - would runoffgroove's Splitter-Blend work for this?
As long as you have a suitable source for the incoming voltage and the current draw does not exceed about 20mA, it could be used.I recently came across these:
https://www.analog.com/en/products/ltc3265.html#product-overview
Any reason why I couldn't power the device with one of these?
