Hi, and thanks for reading.
I have a pair of Gyraf 1176 and GSSL boards i'm looking at building (no probs done it before).
But this time I was thinking;
1. Can I run the Console rails of +-17 into the GSSL? Voltage drop of 0.7 per rail leaves +-16.3 Vin for the Lm7815/Lm7915...1.1V is the dropout voltage... so 200mV to spare..enough? Or can I connect post bridge rectifier? Any special approach required here..?
2. Can I run the +48 into the 1176? Do I use a rail splitter here for 24 0 24? Any suggested circuits..?
I guess current is the issue...? Not sure on the PSU spec here, (no known schematic yet..) it is called 'Soundcraft - Large Console PSU' no numbers I can see, I have two of these supplies connected as intended by manufacturer (Main and Auxillary).
3. Is there a better way? Or another way (apart from using the transformers..) Can I double the +-17V and use that for 1176? Any suggested circuit?
The console is a Soundcraft TS12
The spare panel in center console that could have been automation looks a good place to build these pairs of comps in, nice and close to power distribution and room under the hood for pcbs and of course the panel is for knobs and meters...
Thanks for reading.
Thanks for reading.
