Thank you very much, but unfortunately the link does not open. The file is not located
I'm trying to post the actual link but it keeps showing the Log In link
Thank you so much for your answer and scheme! I was just planning to use EM 204. Thank you so much. And what element base do you recommend, maybe there are some features. I mean Part list (as you have on the site dedicated to RF. AMX10)I've built the circuitry on the attached schematic, using stripboard. Works well.
As I recall, the P48 circuitry which ricardo linked to above needs you to cut tracks on the capsule PCB itself? ...
Not always easy to do! (depending on the capsule type of course)
I haven't done any detail on this project, as I did for the AMX project. I did do a complete stripboard layout for my LDCX2 project (see here: http://www.jp137.com/lts/LDCX2.notes.pdf ) and that took forever! ...Thank you so much for your answer and scheme! I was just planning to use EM 204. Thank you so much. And what element base do you recommend, maybe there are some features. I mean Part list (as you have on the site dedicated to RF. AMX10)
Of course, I can imagine how much time it took you, just a titanic work and a lot of effort you put into it. I have been looking for a scheme for Primo capsules for a long time, I was interested in this when I met the site and the product from LOM. AUDIO , but they only have circular capsules, and I want to use a cardioid. That's why I took the path of search.I haven't done any detail on this project, as I did for the AMX project. I did do a complete stripboard layout for my LDCX2 project (see here: http://www.jp137.com/lts/LDCX2.notes.pdf ) and that took forever! ...
I don't think anyone has ever bothered to build one of those, so I've not repeated the exercise!
There is some detail on how to modify the EM204 and change it into an EM200 to make it suitable for ricardo's 'simple P48' idea here: Primo EM204 to EM200 modification
I don't think I'd be brave enough to try that mod myself!
I've only used my schematic to build stripboard versions for my MEMS ulttrasonic mics. They were fitted into plastic drainpipe enclosures ..
There are some photos of the construction here: http://www.jp137.com/lts/MEMS.bat.experiments.pdf
..and you can see, that the stripboard layout is not complex.
I think I still have a stripboard layout pencil sketch I used for that 'one off' project somewhere .. but it isn't necessarily going to be very legible.
As I say, it shouldn't be a difficult layout to do yourself.
The only other version I have done is for my M/S mic, which uses 3 x EM204s. (There is a photo of that project in post #11 of the EM204 conversion thread I linked to above.)
That time it was all fitted into a BM800 body, so there was more room for the stripboard.
Again, I only have rough sketches of that project layout. The time I spent on the LDCX2 stripboard layouts rather put me off doing a lot of detail for projects no one else was going to bother to build!
The AMX project was different. It generated a lot more interest, was not suitable for a stripboard, layout, and two group members very kindly did the PCB layouts. (Ruud did the prototype -- Khron did the several versions of the BM800 version).
There are several project PCBs for projects like the 'Alice' mic, and those can usually be adapted quite easily, to accommodate simpler internal FET electret capsule versions... like the EM204 for example.
This is a good article with many useful practical points. But there are a number of errors which I've addressed in my MicBuilders article. Tom has corrected some of his errors but I'm not sure he's caught all of them. So if you are building one of these, do read his article/thread ... but get my 'original' too.I guess this is the simpleP48 circuit (or is this even simpler one?) used here: DIY Microphone: EM172 Capsule and XLR Plug
