G-spotrecordings
New member
- Joined
- Dec 11, 2005
- Messages
- 2
Hello,
I'm a recording engineer from Belgium and I signed up today after bumping in on this really interesting newsgroup. I see that a lot of real engineers are on this group. I'm willing to be part of that, but I'll have to learn a lot before being part of this group. Anyway I have a litlle problem that I'm trying to tackle, and I hope you guys might help me out.
I have a pretty high end recording studio (in parts actually cause I'm going to build it within two months if my planning is ok) I'm actually going from totally digital to totally analogue (at least the front end). I do mainly rock music and recording guitar is one of the things i do best but It takes really a lot of time to get the result I want mainly because I have to go from room to room untill I'm satisfied with the sound. I mainly do a blend of three amp at all times (mostly single rectifier, marshall LM6100 and and a JCM800). What I would like to do is have the heads in my studio and the cabinets in the booth. There is a distance of around 20 meters between both rooms. Does anyone know how to tackle this problem with a minimum of signal degradation.
As I use three amp at the same time I would like to build some kind of reamp box. But I'dd like to use it as follows. One guitar in four different amps (in case I might favour four but that's extreme) and a fifth channel back into my daw through my studer 903 mixer and into my daw using Studer V8 ADDA converters. The latter for reamping if I'm not satisfied with the end blend. The guitarsignal gets balanced immediately (api 3124+ hiz input)
For the second problem I found some partial answers on this site. What I was thinking about was to split the balanced guitarsignal from the api into 6 channels (1:1 transformers) The splitter will be a sparecard I have for my studerdesk (eurocard system). The thing is to unbalance the balanced signals enough to use them as guitarampinputs going down at least 14 db. What kind of components would you guys use if the budget was of no importance? I'm not a pcb wizard I can solder well but I have just a litlle notice of audio electronics.... Any help would be highly appreciated. I would like to use this opportunity to get into building solutions to problems as they present themselves. And a lot of projects I have seen on this newsgroup got me drooling so looking really forward to learn.
Kind regards from Belgium
Geert
Geert
