user 37518
I've worked with some B&K mics aswell for instrumentation purposes, they are rather odd, they dont work with the traditional phantom power but rather something like 200V, they have an external supply that feeds the DC to the mics, but the output of the supply is not amplified at all, it has unity gain and the outputs are MIC level BNC unbalanced with an output Z of about 25 ohms, a lot of gain is needed to bring the signal up to an optimum level, I actually ended up using an AD797 in a standard non inverting configuration, the Noise figure is a non-impressive 5dB due to the low source Z, but it works quite well. I thought of adding a transformer after then BNC output, but I dont want to color the signal even slightly.
