blo1017
New member
Hi, guys. i’m using Tube-Tech CL-1B (Maybe 9000 ~ 10000 serials)
There's some problem on VU Meters.
With the VU meter adjusted by 0 point at Compression, there is no problem with the COMP level or output level, but the input level is always measured about -1~2dB less.
I purchased and replaced the VU meter myself, but the same symptoms continue.
So I measured the 3k6 resistor on the PCB Board, and it's about 3k2~3k3. Is there a problem with this resistance that causes this problem?
