Minion
Hi folks ... I am working on a Simple tube guitar preamp project and I am haveing problems ....
here is the schematic ...
The EQ section works fine but the tube preamp section is giveing me headaches ...
Here is the Problem ...
I turn on the power switch and after a couple seconds (as the heaters warm up ??) I start to hear and nice guitar tone but it quickly breaks up into a squeeling feeding back mess....
The heaters are at 12.8v AC and the Plate is at about 70v DC , there is a Voltage doubler comeing off of the 12.8v AC to make a +/-15v supply for the Opamp which is a OPA2107 , the Voltage doubler has 2 100uF caps per rail with a Voltage divider or two 33k resistors going from each rail to ground ......
The squeeling happens with the Pot between the Tubes all the way down and with the Input opamp gain all the way down .....
I"m thinking that maybe the tube Bias is off or something but this is only my second foray into the tube world and am severely lacking in tube knowlege ??
anyone can help me here ??
Thanx a Lot ...
Thanx a Lot ...
