Hello everybody
I am in the process of building a vari mu compressor with tube rectifier in the power supply
using an Hammond 370EX power transformer and a GZ34 rectifier tube
http://www.hammondmfg.com/pdf/EDB370EX.pdf
http://www.newsensor.com/pdf/sovtek/5ar4-sovtek.pdf
There is something obviously wrong. I am testing the power supply circuit without connecting the rest of the compressor circuit and rectifier tubes keep burning !!
The wiring has been triple checked and there is nothing wrong, I don't really know what's going on. The power transformer outputs around 630V AC to the rectifier tube and the 5V for the filament is fine too. The first PSU capacitor is rated at 450V and that should be fine too, but there is absolutely no DC voltage on pin 8 of the rectifier tube, which after a few seconds from power up just emits some sparks and it dies out.
I have already burnt two rectifier tubes and I will definitely need some help before I do more damage
This is my first build with tube rectification, I didn't expect something could go wrong, the wiring is very simple. Maybe I didn't choose the appropriate rating power transformer ?
I hope someone can help me out so I can manage to get this working. Thanks in advance
