For Sale PROJECT SUPPLIES: ACTIVE DEVICES, CONNECTORS, POTS, PROJECT CASES, TRANSFORMERS, WIRE, and more! GroupDIY pricing.
13engrsapper
GDIY Supporter
Charleston, SC - USA
Active Devices:
Coming Soon - Diodes, LEDS, Transistors, Opamps, Voltage Regualtors and more.
Connectors:​
  • Switchcraft PXCST Female XLR and 1/4" Combo Jack. $4.00 Each plus shipping.​
Gold-plated contacts, straight pc pin. 98 available.​
Project Cases:​
  • Hammond 1456PK4WHCWW sloped cases with solid walnut sides. Build a Mini mixer... mic pre... you name it. $55 each or $90 for 2 plus shipping.
We have 8 6 of these available - if anyone has any use for them let me know. These are all brand new in their original package (cardboard wrapped with shrink over that)... well 7 are still wrapped. These are nice-sized units (total width of about 14 inches) with a vented bottom and back, solid walnut sides (yes, real solid walnut). The bottom is steel, the top is aluminum. These could be great for many projects discussed here in GroupDIY. The PDF with all the details is attached. They are about 4-6 pounds each.
  • Hammond 1458VC4 - Vented Case excellent for external power supplies, mic pre, etc. $40 each plus shipping.​
Roughly 6 x 6 x 4" externally. We have about a dozen of these on hand. They are REALLY nice little cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1458D5 - Non-Vented Case excellent for external power supplies, mic pre, module rack, etc. $40 each plus shipping.​
Roughly 8 x 8 x 5" externally. We have about 5 of these. Nice cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1458G5B - Non-Vented Case excellent for external power supplies, mic pre, module rack, etc. $45 each plus shipping.​
Roughly 10 x 8 x 5" externally. We have about 8 of these. Nice cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1590B - Die-Cast Stomp box enclosure, an industry standard for a reason. $5 each plus shipping.​
Roughly 4.4 x 2.4 x 1.2" externally. About 100 90 on hand, I am not counting all of those now. Bare aluminum We can machine/drill your cutouts/holes if it helps.
  • Bud CU-124-G - Grey Die-Cast Stomp Box enclosure - Same size as the Hammond 1590. $6 Each plus shipping​
Roughly 4.4 x 2.4 x 1.2" externally. About 80 67 on hand. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Bud CN-5706 - Die-Cast Stomp box enclosure. $8 each plus shipping.​
Roughly 4.7 x 3.9 x 1.4" externally. About 100 51 remaining on hand. Bare aluminum. We can machine/drill your cutouts/holes if it helps.
  • Hammond 1590XXOR - Die Cast Enclosure. Orange. $10.00 each plus shipping​
Roughly 5.7 x 4.7 x 1.5" externally. About 100 94 on hand. Facory Orange. We can machine/drill your cutouts/holes, or laser engrave if it helps.
Transformers (Audio)​
Transformers (Power)​
  • Hammond 262B6 - 120V Pri: 120V, 6.3V secondary $15 Each plus shipping​
This is the physical size of an Altec 1566 transformer, FWIW. 11 9 available.
Wire:
  • 14AWG (2.5mm) SIAF Wire - White - 100M (328 ft). $85 Each plus shipping​
  • 14AWG (2.5mm) SIAF Wire - White - 20 feet. $11 Each plus shipping​
High Temperature -60 to +180 degree C. 500V tinned copper flexible core silicone jacket. 3.5mm overall diameter.
  • 16AWG (1.5mm) SIAF Wire - White - 100M (328 ft). $85 Each plus shipping​
  • 16AWG (1.5mm) SIAF Wire - White - 20 feet. $11 Each plus shipping​
High Temperature -60 to +180 degree C. 500V tinned copper flexible core silicone jacket. 2.8mm overall diameter.
  • 18AWG (1mm) Equipment Wire - Green/Yellow - 100M spool (328 ft). $30 Each plus shipping​
  • 18AWG (1mm) Equipment Wire - Green/Yellow - 20 feet. $3.75 Each plus shipping​
1500 Volt tinned copper wire. Stranding is 0.2mm x 32. PVC Jacket. 2.52mm overall diameter.
  • 19AWG (0.75mm) Equipment Wire - Brown - 100M spool (328 ft). $25 Each plus shipping​
  • 19AWG (0.75mm) Equipment Wire - Brown - 20 feet. $3.75 Each plus shipping​
1000 Volt tinned copper wire. Stranding is 0.2mm x 24. PVC Jacket. 2.0mm overall diameter.
  • 20AWG (0.50mm) Equipment Wire - Pink - 100M spool (328 ft). $25 Each plus shipping​
  • 20AWG (0.50mm) Equipment Wire - Pink - 20 feet. $3.75 Each plus shipping​
1000 Volt tinned copper wire. Stranding is 0.2mm x 16. PVC Jacket. 2.0mm overall diameter.
More coming, check back soon!​
Feel free to ask questions.
Thanks and take care,
-Tony
amp-haus
  • 1456PK4WHCWW.pdf
  • 1458CV4.zip
  • 1458VC4.pdf
  • 1458D5.zip
  • 1458D5.pdf
  • 1458G5B.zip
  • 1458G5B.pdf
  • 1590B.zip
  • 1590WB.pdf
  • hb123.pdf
  • hb123-1.dxf
Hammond sloped cases with solid walnut sides (1456PK4CWW) - Mini mixer... case, mic pre... you name it. CNC control box... more types coming.
And.....I have the 3D CAD-files of this HAMMOND sloped case:
>> What this means is.....a purchaser could describe to me where they want to have which cut-outs and holes put where and I could input that information into this HAMMOND 3D CAD-model. Then, I could send the modifed CAD-file off to 13engrsapper so he could use his machinery to insert/punch the cut-outs and holes into your new casing. Well.....that's at least how I do my sheet-metal work.
I'm just trying to be helpful here!!!
This does not appear to be the same one, though? The case for sale appears to have a flat top. Pretty sure Hammond makes all the 3ds available for their products, though
Yes they are good about that. I have the STP and IGS files for the box here.
  • 1456PK4WHCWW.zip
  • 1456PK4WHCWW.pdf
[I have the STP and IGS files for the box here] -- I don't know if this will mean anything to you or not, but HAMMOND also provides another CAD-file format called -- .x_t -- which I found to be rather interesting. What is interesting about this file format is that (at least within my SolidWorks program) it acts and behave as though it is a "native" SolidWorks file!!! In other words, the IGS and STP files load-in and behave something like an AutoCAD "block" entity, meaning.....after importing an IGS or STP file of this enclosure into SolidWorks and I click on any geometry of the enclosure, that click selects the entire object. However.....after importing the ( .x_t ) file of the same enclosure into SolidWorks and clicking on an item (face), -- ONLY -- that item is highlighted and I can manipulate -- ONLY -- that one single item.....JUST AS THOUGH I HAD CREATED THE ENCLOSURE DESIGN WITH SOLIDWORKS ITSELF!!! WAY COOL!!!
What this may or may not mean to you.....I have no idea. But, for me.....it means a whole lot!!! And, I have also been noticing that several other manufacturers of electronic components and parts are also providing the ( .x_t ) format.
I can have any of them powder coated Lime Green - for an upcharge. If you are wanting other colors, buy an already painted one, then you do not have to deal with priming aluminum. We can laser engrave or machine holes in any of the baxes for you too.
Likely will be listing a bunch of other stomp related parts/components.
There are tens of thousands of real vintage germanium transistors here too - they have been sitting decades waiting for a project. Real ones, not the fake ones China is selling on eBay etc. lol. I was looking at some of the Chinese Fuzz kits. They picture 2 AC-128 transistors with a Motorola logo in a TO-5 sized can. Some of the older than me guys may have other experience with the AC-128, but they were NEVER made by Motorola, and NEVER in a TO-5 can (they were TO-1). Bad fakes, I wonder how many poor souls have fallen for that fake Chinese crap.
