dasbin
I built a couple of Fabio's 312 boards and have them nicely in a rack case, and all seems well (well, mostly... check the 312 thread her in the lab for more). I'm wondering, though, what the ideal solution to for grounding is. Right now I have a star-ground on the chassis that EVERYTHING goes to:
- Power trafo 0V Centre-tap
- IEC Earth
- Ground reference for the 312 cards
- Input and output cable shields (through chassis)
I have a nagging feeling that this isn't the right way to do it, and that my 312 card grounds should be seperate. The obvious way for this to happen is to remove the power trafo centre-tap from the star-ground and connect it only to the cards.
Unfortunately though, as soon as I do this, my power trafo stops working and doesn't give any voltage on the outside taps. I've had this problem in the past with every centre-tapped transformer I've ever used... unless the centre-tap is connected directly to IEC ground, the trafo doesn't work. Why is this? I thought it was DESIGNED to be an isolated ground.
- IEC Earth
