Ok, I have a decision to make and I'm quite bad at it... So I need your help and recommendations.
I have an 24 channel modular frame Acousta DCA broadcast desk, a Motu 16A interface and some outboard gear.
I'll probably get another 16A or a Motu Monitor 8Ch interface in the future.
My desk has balanced direct outs and switchable balanced inserts. I will load the desk with 22 Mono channels (6 of them configured as groupchannels) and 2 stereo channels. So 26 input and 22 output channels (the stereo modules don't have direct outputs but have inserts). Plus Aux and Master section (8 inputs and 12 outputs).
I already wired a Lemo patchbay but did some mistakes and will probably do it all over.
The inserts are already on a seperate Lemo patchbay.
The question is, do I need/want all the direct outs and line inputs on the patchbay? Or should I just "hardwire" them to the interface ins and outs?
I fear that I'll regret it in the future and need the flexibility of having all connections on the patchbay.
What are the scenarios where one would route the direct outs to another source instead of interface (other than recording to tape, which I don't plan to do...) Or when would one route the DAW outs elsewhere as the Line inputs from the console?
Also the Lemo patchbay I plan to use does not have the shields/connectors isolated. The other Lemo Patchbay I have here, were I did some mistakes, has less patch points but has isolated connectors so I can decide where shields go.
Pin 1 of the console XLR connectors are all tied to signal ground inside the console. There are 3 seperate, isolated lugs on the back of the console for the 3 different "grounds" (signal, chassis, PE). All Line, Mic and Aux inputs are transformer balanced, the same with the Main and Aux outputs. All Inserts and Direct Outs are electronically balanced.
Pin 1/shell of the Motu 16A jacks are tied to chassis inside...
Can somebody please solve my brainfart...
PS: the console has two inputs per channel, each with it's own input transformer. I'm using inputs 1 for mics and I plug them directly into the console and I can switch between channel 1 and channel 2 on the console. So my questions is just about line signals.
Phantom power can also be switched independently for each of the two input channels.
