Thanks for all those comments. Yes, as mjk points out, speaking precisely there is a bias, because of the one prohibited lock-up state. This gets as small as we like with longer SRs.
I don't care if the noise is exactly white, and I realize that some of the criteria for mimicking a true stochastic process will probably not be met. JDB's suggestion is probably workable and likely the most elegant for my needs.
What I'm after is something to use as a modulator for PWM resistors in a filter application. I'm concerned about heterodyning artifacts that might be generated downstream with one or another variety of switchmode amplifiers.
I'm thinking that a bit of extra noise as the effective artifact would be far more tolerable than whistles and tones.
Now, one can work out how to synchronize the pwm resistors to the switchmode amp, possibly, in the case of the more conventional fixed-freq pwm; then you have the likelihood of offsets at some level, but these can be highpassed out---as long as the variation in the PW is reasonably slow, which it would be in this case. If the switchmode amp is variable frequency then things get more complicated.
And then there's just the notion of keeping the system sufficiently clean and lowpassing or otherwise comb-of-notches filtering the filter outputs ahead of the power amp. But my experience has been that once you start listening for things it's amazing how deep into the noise you can detect them.
The PWM resistor approach to varying filter parameters was used in an old JBL-branded aftermarket-automotive line-level crossover product years ago that Brad Plunkett assisted Robert Girard with in development. The pwm approach was mainly an expedient to allow single-section cheap pots to vary a multitude of channels of filter. It worked reasonably well, although in its day the class D amplifier it might have fed was a rarity.
