yes I would remove R30 all together. If your lucky it will stay at 295V but I have a feeling it my dip a little under load. If it dips too much like to 280V the regulator might not be able to filter out all the ripple. You may have to adjust the zeners for a little lower voltage. I found with 20V to be the perfect differential using a TL783 voltage regulator Good balance between power dissipation and ripple rejection. This circuit works differently than that so results might be different. Just try and see.
