Another UPDATE:
I had to mix down a song for a band this week & had a chance to run some thru my new Dual Pultec. I did a few my standard way then a few thru the Pultec, taking notes & pictures of the settings so I could go back & listen.
Everyone in the band liked ALL my standard mixes but ended up choosing the Pultec one. :green: It was just more defined, had a nice, none offensive flavor to it & tightened up the bottom end (which is the hardest part to get right when mixing). We all love bass but it can kill or make a mix. The Pultec seemed to move it into an upper low range and control the "loose" SUBs.
While the mix was up & after the band left, I decided to install the 600:600 Input Trannys to have a listen & run test.
The TX was also cool but did have a hair dirtier highs... but the lows were nice & I think I could hear the better CMRR, especially in the holes of the mix & especially in the lows & definition of them.
But in the end, the band chose the HYBRID Version of the mix over all the others (which BTW got sent out today to go on a Compilation CD with other pro bands) I could have picked a few different mixes myself... even ones without the Pultec at all but I did like it a lot.
So, the HYBRID it is :grin:
It's universal & can happily marry with whatever I plug into it & it sounds great!
Now... my final test is to try my Cinemag in front of the HYBRID.
I still have the same mix set up & untouched, also all the setting on the Pultec have not moved from the favorite/Best settings we picked for the mix.
I'm going to try this... & most likely mount the transformers in my patch bay so I can use them with other units as well.
NOTE: ALL of my output (main & inserts) are unbalanced on my console.
After reading the info from JENSEN... it seem that adding the input TX can significantly improve CMRR, among other things.
Also, I'm not using the Jensen, I'm using Cinemags equivalent CMLI 15/15B.
MY HYBRID IS SET UP EXACTLY LIKE THE "PRO TYPE INPUT" shown in the diagram - Unity Gain.
(Original PDF)
http://www.jensen-transformers.com/an/an003.pdf
Hopefully some of you guys are getting something out of this thread...
If so... please let me know. I'm doing my best to learn, test & share what I can.
& once again, thanks to all who have helped.
Kevin
