khstudio
[quote author="Greg"]These are the two quotes I was referecing, perhaps I read them wrong:
[quote author="khstudio"]The schematic IS exactly how Pultec did it on their SS model but that doesn't mean it's the BEST option.[/quote]
[quote author="khstudio"]Now, the SS Pultec isn't set up exactly like the 312 but I wouldn't think it would cause the offset to change. :idea: :?:[/quote]
Anyway... I think you should look at changing your bias resistor or use an inverting configuration with a DC trim resistor. Both of these could lower your DC offset. I don't think you will be able to eliminate the need for a coupling cap, but lowering the DC offset should allow you to use a lower cap value resulting in less "smearing" of the audio.[/quote]
Greg #1... thanks for helping. :thumb:
#2... I see NO connection with those 2 statements... you definitely read it wrong... sorry bro.
Once again,
when I measured the DC offset (In My SS Pultec circuit - using the 2520's) it scared me BECAUSE I thought it was the 2520's causing it. I new it was high & I was concerned about my 8 channel API 312 I just finishing up - & didn't plan on or want to use output caps. Nor did I want to send THAT much DC thru the OT's & especially, Damage my new 2520's that I waited almost a YEAR to get!!!
I hope this makes sense.
The SS Pultec circuit (Draw by PAT) DOES require an output cap & I have no problem using one. It does sound very good as is but that doesn't mean I won't revisit possible changes to the output amp or setup down the road.
Like I said, I still have a long way to go with learning about electronics but I've come a long way & I'm no dummy or lazy.
Some of you guys have a lot of background & knowledge & sometimes take for granted, things that seem easy to you are not so for others.
But that doesn't mean we can't learn.
My ultimate goal is to have great sounding gear & an understanding of it so I can make great music!
I'm a Musician & Engineer 1st... then a tech.
I'm also a cool & sharing dude... despite what some might think.
Once again,
