Pultec transformers
bram9206
Hello all,
I'm almost finishing my Cayocosta layout, point to point Pultec clone. I was just about to wire my original Triad HS 56, but I was wondering if I should wire it 600 Ohms or 250 Ohms. For the output stage I used a Sowter replacement and I must say I don't know, according to Cayocosta's layout, what resistance it is wired for.
Anyone any idea what resistance I should choose? I know the original Pultecs are wired 600 Ohms, but is that still in accordance with today's standards...?
i think the schemo says 600:600,
250 on the input would be for matching up a low Z device to the input,
most of that 200 ohm stuff is history by now,
Any opinions about using Edcor WSM600:600 and WSM2.4k:10k instead of the Sowters as input and interstage tranfos?
What do you think? Could the lack of shielding in Edcors be a problem in this circuit?
For the output I don't think there is any options for the Sowter...
Thanks CJ. You mean like all my old mic stuff, like RCA DX77 etc... ;-) So in my case I guesse it would be usefull to make a switch to choose between 250 and 600 Ohms, right? Or would you go for the 600 Ohms anyway?
600 ohms is a hard load to drive.  250 is even harder to drive.  Remember that the Pultec input has termination on the secondary so it is presenting a real 600r load (or 250) to whatever is driving it.  I assume you may be thinking in terms of ratios only 1:1 vs 1:2 etc.  I can't think of any good reason to strap the input for 250r.
Most would probably say that today's standards specify a High Impedance bridging input.  The only practical way to get that using an input transformer is to use a 10K or 15K:600.  But the problem there is the loss of gain.
The secondary is wired for 600ohm.  Did Sowter send you a schematic for the 9530?  If not, pink & white are the signal, grey & blue/yel are tied as the center tap = 600r.
