mikep
Reading the servo thread reminded me of this little idea I had:
the offset will not be perfectly zero because of the DC offset coming from the node that includes the opamp's minus input pin. however, the source-Z, if you will, of that offset is quite high and with a low-z load it is pretty much swamped. it is also not a problem (stability wise) to short the output to ground or a DC voltage. there are some interesting effects at LF into low-z loads. for one, the AC feedback around the caps tends to lineraize them, but if you slightly undersize C2, it can be made to overcompensate, you actually get a bit more LF energy into stiffer loads.
comments? Id like to see other examples of output caps included in a feedback loop if anyone has one.
mike p
![capfeedbackop.JPG](https://proxy.imagearchive.com/701/7019cca21b2fd2f1cdf78c242e27d478.jpg)
mike p
