Putting mic inputs on Dsub? Crosstalk?
Well - don't quote me on this - but i would think crosstalk would be a bigger problem on higher level signals like line level.
It may be an issue if you have a really hot signal adjacent to a really low signal....but other than that?
Edit: i'm assuming you are using individual screened pairs in the 8 way cable - or even if you use  ribbon d--subs - if the pinout is correct, each hot/cold pair should have a screen either side in the ribbon.
I've seen many edac/harting pinouts on pro consoles that have a common screen and hot next to adjacent hot pinouts without any noticeable crosstalk at mic and line levels!
j.frad said:
Hi!
Would there be a reason not to put mic preamp inputs on Dsub connectors?
Should be OK as long as wires are shielded up to and from, and connecter is mainly used for semi-permanaet instals. Also do not common any leads, even if all pin 1s end up in same place.
A pin sequence of 123,123,123 will place a 0V (pin 1) between each pair of hots.
I wouldn't trust DSUB for live use and many insertions. They were pretty popular for -10dBV studio snakes albeit not at mic levels.
Real console multi-pins are pretty expensive so it sounds worth a try if on a budget.
I just realised my friend's ULN8 has mic inputs on Dsubs and it's fine.
My concern is about space trying to fit at least 8 preamps in 1RU and all connections at the rear.
I could use edacs...
I'm in the process of making a d-sub patchbay! I'm getting into surround mixing and want to be able to switch connections in banks of 8.
I am going to use ribbon based d cons and then buy a bucket load of PORT SAVERS - they cost about £1 each in quantity - just cover your sockes in these and then bin them when they get unreliable and put a fresh set on!
