Svart
I've been doing a lot of opamp simulations lately. Yes simulations, but i'm finding that the spice models are close enough to really work and are fairly close in real life.
that being said, I'll get into my questions.
I've noticed that a few models have a tendency to round the leading edge of the output signal(1khz Square) and the rise/fall times are slightly longer than the input signal. While this is more pronounced at high frequencies, they can be made to exhibit this at much lower frequencies through various methods(more output capacitence and such).
I have not explored much further but it seems that some opamps are much more prone to this behavior than others. The AD810 is more prone to do this with more output capacitence, while the ne5534 tends to have a crazy overshoot and ring with the same load.
So, other than testing with prototypes, would there be any interest in actually tailoring a certain signal responce from an opamp to change the qualities of the signal itself? I could see this giving the "color" of the opamp, something we talk about a lot around here.
any thoughts?
any thoughts?
