I have been researching guitar amp circuits and noticed vey few amps use a cathodyne type circuit
Longtail is "newer", late 1950s. Go further into the past with a wider net. Many many cathodynes. Before that, many "paraphase" inverters (a natural for modding an SE model to P-P, especially with a common-cathode twin triode).
Just in the Fender DeLuxes:
Paraphase: http://schematicheaven.com/fenderamps/deluxe_5a3_schem.pdf
Semi-floating paraphase: http://schematicheaven.com/fenderamps/deluxe_5d3_schem.pdf
Cathodyne: http://schematicheaven.com/fenderamps/deluxe_5e3_schem.pdf
Longtail: http://schematicheaven.com/fenderamps/deluxe_6g3_schem.pdf
The 5E3 cathodyne works for many musicians. Some plucker named Neil owns dozens of them. His specific feature is the wonked Vol/Tone network, but he clearly knows how to hold a cathodyne on the very edge of grid blocking.
Fender/CBS felt some ownership of the longtail, so you see other amps using or reverting-to cathodyne well into the 1970s. My Ampeg VT-40 is cathodyne, but I think an earlier model was longtail. Early Sunns were all taken from Dynaco: pentode-cathodyne.
it seems to me... that the cathodyne PI would be better at driving the grids of the output tubes especialy when you get into AB2 land...
No capacitor-coupled grid can go AB2. Don't matter what kind of driver, until you get to absurd dreams like a driver and caps bigger than the power stage. Geetar amps "touch" AB2, and it affects the way they are used, but they can't "work" AB2, the cap charges-down and puts the grid more negative.
The exceptions prove the rule. Ampeg SVT uses a 12BH7 buffer direct to the 6146/6550 grids, though a grid resistor limits Ig to a few mA. Fender 300PS uses a 6V6 (yes, a Champ) and an interstage transformer to slap grids. Before these beasts, we have to go to the late 1930s to find a guitar amp with significant grid current, and then only because before 6L6 there was no cheaper way to get stage power.
For the short moment when the cathodyne cathode tries to pull the lower P-P grid positive, the signal at the cathodyne plate slams negative. The longtail's plate loadings have little effect on each other.
The longtail is easy to cripple so that it can put plenty but not too-much drive on the power tubes' grids. For common power bottles, it tends to happen naturally. OTOH, for high-gain EL84, a stock-proportion longtail can slap the grids so hard into cutoff that it don't recover till halfway through the next verse.
The longtail has two hi-Z inputs, which allows using a pot and nice-size cap in a NFB loop. Cathodyne will invariably have a volt-amp, usually a simple tri/pentode, and a low-Z input at the cathode. Fine for simple resistive tapping of speaker winding, but not for fancy stuff.
The fancy stuff is the 5F6-A Presence control. Note also that it injects to the common cathode as well as one grid. This changes P-P balance. With the presence cap, P-P balance changes mid-band. This is apparently interesting to the ear.
why is the long tailed pair so popular?
MANY more gitar geeks at
Hoffman's.
