0dbfs said:
I use bits of cat5 wire for this and tons of other things. Stranded. It's very cheap and you get 8 different colors.
Never had a prob that I could blame on the wire.
Ciao!
jb
that cable type is very versatile ,
ethernet apart ,
can be good for wire many type of "control" connections ,
and power too , like leds , switches that drive relays , and related..
with adequate attention of the max voltage/ampere supported limit ,
but for internal box interconnections audio signals
in professional analog audio recording and processing devices ,
better use a specific dedicated type of cable ,
because some unexpected unpleasant sound surprise could appear….
from a various thousand bucks microphone…..
also better use proper good quality cable for connect the mic to the preamp ,
and same for line type like preamp analog out to AD converters
between outboards , from DA converters to mixing console or for analog external insert routings ,
and for electric guitars the "thing" becomes even more delicate….
the cable can be ( or is) an Eq.
