Hi Guys, i had a question regarding a Fender Twin reverb Silverface 135W RMS (1979) that i have on my bench.
A friend of me wanted me to check the amp and see if there are any failed components etc..
That obviously leaded to two Filtering caps that had to be replaced, and so i decided to replace them all, and i had to replace some other small things as well.
At first i had loaded some old schematic (aa769 and aa270) missing the good one huh, and it was not looking and measuring near what i had, and at first i tought it was a modded one, below is the correct one, with a HT at 500VDC , looks a little high for the life of tubes, and i guess he'll need to always make sure to grab some tough ones, he is actually using matched pairs of JJ 6L6GC, and they seem to be up to the challenge (seems at limits tough), while i think a lower HT would be nice to have here, using a Big Resistor for example, or some other method? What do you think?
The main difference along with some others, from the old schematic, is the rectifier, new one is a full wave bridge, while the old is a Full Wave rectifier, i don't have the snubbers on the bridge rectifier tough...It's a point to point build btw.
It's a safe amp to work with, cause it seems there is already a bleeder installed a 30K 20W.
http://ampwares.com/schematics/twin_reverb_sf_135.pdf
Ok My question is regarding the biasing of the amp, i wanted to check that as well, and when i do the simple method of the 1 Ohm on Cathode to GND, i read 5mV wich makes 5mA, thats' a little odd and looks very low for what that amp can deliver. (EDIT: Tubes IN and Speaker IN)
On this amp, and as you can see on the schemo, there is a "hum Balance" control, so current balancing of the Heaters (if i got it correct?), and "Output Tube Matching" control, wich will perform about the same i guess but for the pair of tubes, but that doesn't look like a real bias adjustment...
Id like to know how i could mod it for beeing able to really adjust the bias, with a pot would be easier as always, i understand that a simple method would only be an adjustment for all 4 of the power tubes, and not by pair or by Tubes, but that's better than nothing here...
But maybe there is something else going wrong for having 5mA on each tubes.
Anyway there are couple of things on the web concerning Bias mod on Fender amps, but i'd like to have your toughts here, i could have posted in an Guita amp forum, but i'm use to here, and there are Masterminds and courtoisie, wich is important to me as well...
Thanks a lot for any feedback, i'm not a pro in the Tube Amp domain, so i'd like some toughts...
