Thanks a lot, Winston :thumb: You eased my mind inedeed! :guinness: :guinness: :guinness:
I put a old (used) Valvo EF86 into channel A. With the stock tubes ChannelA was a bit noisier than Channel B. The Valvo was considerably lower noise, Channel A is now better than Channel B. I got another new or almost new Valvo that measured very well, but the noise on that one was higher. Seems like you have to go through a number of them to find one that's really low noise. I may be a bit pickier about noise than most people, though. The noise floor is not really a problem. As I said, the sound is really nice, no buzz. So I guess I'm fine. :grin:
The 206V HT voltage was measured at the PSU section. There is a test point or jumper that says 250V. Gotta take a look at the input transformer. The unit I have is indeed one of the later ones with the DI jack on the front pannel. I bought it early this year when the German distributor sold its remaining stock. BTW: I talked to a guy from the ex-distributor team at the Musikmesse, and there was a bit of regret given the popularity of the new models.
One question about the output impedance switch - are 600/10K the actual output impedances or are those the minimum load impedances? The manual is a bit unclear about that point.
Have a nice weekend!
