plumsolly
Not real sure here... In the console, all grounds (including power supply common) are tied together at one point... So if it does not work without tying them together, then I think you would be ok to run a line from Ov to your star ground point... maybe someone who knows more about electronics will chime in As far as the gain, these are pretty hot preamps even with a 10db loss at the fader (which you don't have). What your describing sounds about right. Get your gain staging right before you make a judgment about noise; these are not the quietest amps, but they should be fine for almost every situation. Best, Ben
