I think the first steps should be removing the tube. Is it still noisy?
Then, does the output volume pot turn down the noise?
NoisyIndividual, you brought up some really insightful and great points that I'm gonna follow asap as time allows.
Thank you for your awesome reply!
Let me please do some quoting NI (Noisy Individual)
Your reply is totally appreciated and so spot on to solving this!
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yes, you can turn down the noise and signal at the output completly IIRC, and turning down input gain, does nothing to the noise IIRC, it keeps flashing RED at the clip/limiter LED.
Another possible source you can rule out is the cable and mic, both are toally fine, I checked with another preamp, so that is out of the way, it's just the preamp that is faulty.
Removing the tube gives easy access to the first grid, you can easily scope that pin of the socket to see if the noise is there.
Or even use the DMM on that grid point. If the voltage jumps around, your noise is probably present.
Yes this is basically the solution to what I suspected as possible noise origin, that the noise almost has to come from or before the stube stage.
Because why would the noise increase unless it was increased going into the +20 db switch tube stage, which runs the tube hotter into grid 1 and 2 and incerases signal with noise together.
Both tubes 5751 and 12ax7 shouldn't go bad simultaneously. Tested with both several times, both have the same noise behaviour.
Edit: except I forgot you said the noise is much worse with the pad switch lifted, so it is probably somewhere in the initial mic pre, not the tube onwards.
Those are great points NoisyIndividual,
Right now phantom power 48V is always on literally soldered to on.
Are the "first stages of the mic pre" before and leading up to Q2 and Q1 a voltage doubler with rectifier? I mean all those diodes and caps before those TIP112s amplifiers.
Do you suspect the noise coming from there?
If it's coming from that end or beginning and I unsolder 48V phantom to off position, it should stop the noise, shouldn't it?
If only I had done that first, I soldered so much today and unwound 2000 turns of transformer wire, and we have night.
But that phantom switch would really narrow down the source, as you can see perhaps in the dark image in OP,
in the picture from left to right SW2 is missing.
The push button link became electronically/damaged unstable and I don't want to destroy the attached mic by pulsing 48V phantom into it, so I made a "trace" joint by a wired joint soldered on for 48V phantom, it has 6 trough holes, I only soldered the pins the have contact when the buttons gets pushed in, so 4 pins have been contact with each other, I know how the push button looks and connects from the inside.
But will after having tried your suggestions first, remove it completely.
Because the clicky push button failed on reassembly, I managed to put this fiddy thing together, but humpty dumpty is not 100%.
so I discarded it for now and just bridged the joints of SW2 (i.e. Phantom Power SW2), they count the switches from left tot right, with solder and wire, so I will also have to unsolder that possibly, and see if the noise source is phantom power.
But it stayed at 46,5Vrespective to ground, the whole time steadily. But with a digital multimeter, and mine is a cheap 10€ one, you can't see sudden 100mv fluctuations that easily I believe, there could definitely be noise there. going in to phantom 48V.
I really learned something from you today by probing the grid with tube unmounted!
I will totally remove the tube and scope on Grid 1 when time allows, so far I only checked the cathodes LT sitting 6,7 V IIRC earlier today.
The +33V was doing sth. at 29,7V IIRC at Q1 in circuit and fluctuating a bit by like +-0.4V, but I vaguely remember this, but I 100% saw it on the digital multimeter.
I have an older siemens DMM that is more sensitive and has more resolution in the Voltages possibly that would work better error search/fluctuating voltages than a cheap 10€ modern DMM.
I would clean/check very carefully the gain pot and the wiring to it, and the electrolytic C19 attached to it, for some reason these caps are a point of failure in these types of circuits, creating monstrous noises.
Definitely, thank you!
Input gain pot has become a bit wobbly or less sturdy, it should be replaced probably.
Will resolder that too.
