Hi All
Here's the next of the couple of projects I have in the works at the moment.
It's a dual limiter, done 'poor' style but with some interesting bits and pieces.
Based very loosely on the rca style of limiter, and with bits and pieces from other of the similar configured units like the urei 175 and so on ... and drawing a lot from the forum members discussions over the years .. and also with some truly inspired builds that some members have shared along the way.
One channel uses big octal tubes, one channel uses small tubes and are the same apart from that.
So - classic style of limiter with utc input transformers and Edcor output and Power supply transformers with some classic old chokes.
Pentode GR tubes with interstage transformers feeding amoderately seriously beefy line amp. Sidechain is simple high impedance style with tubes for regulator and rectifier.
The rest is 'put' together using parts that I have already and my usual very generic 2RU case and home 'wreaked' panels with safmat labelling. All in all, fairly quickly done-as-I-go production values, fairly typical of my approach.
Meters are mci/triplett with vu buffer assembly - coolio. After using these there is no going back.
Absolutely exqusite sensitivity to music and ballistics that is just wonderful.
They are going to be switched between GR and VU which will be a little hack of those nice meter buffer cards
I end up with a very servicable 'prototype' kind of unit rather than a meticulously made build or commercial one.
This is probably the last of these kinds of builds for me - I have way too much 'prototype' style of stuff!
After these builds I am discribing in these preamp and compressor threads, that's pretty much it for building.
Anyway, there are one or two things left to complete along the way
So there it is - a dual classic style of tube limiter done in a way that interests me.
Here's the basic chassis at the first interesting stage of assembly
