DaveP said:I buy these pre formed boxes in the UK:-
http://cpc.farnell.com/jsp/level5/module.jsp?moduleId=cpc/256377.xml
I try to use them as modules and join them together but sometimes I buy the biggest box and jigsaw off sides and corners to get the shapes I need. Then I just pop-rivet or screw them together...
DaveP said:It took as long to reconstruct the meter as it did to make the entire front panel.
leadbreath said:so how does it sound???
Mike Cleaver said:Very nice work!
Yeah, the metering was necessary back in the day when we used these for radio.
Every Sunday night, the stations would sign off at midnight for maintenance until 6am Monday.
We'd go over everything in the studios/control rooms, then drive to the transmitter to check things there.
Running through the metering for the tubes was a weekly check.
Hope it sounds as good as it looks!
DaveP said:So I could hear audio, I stuck a matching TX on the output and attached a speaker! It actually makes a reasonable practice amp, it has so much output!
bobschwenkler said:This is something I've been thinking about some. Would it be more ideal to modify the gain of the output section or is a pad just fine?
