Well done!
At that price you can risk it. Build your confidence by checking it all through yourself, its the only way to learn.
When you get them, check out the contacts and make sure the internal ring will be there for the number of contacts you need. Wiring switches is tedious painstaking work, but it has to be done right. Best to wire up with coloured wire and make a note of what's what before you fix it in the panel, not a job for late night work.
good luck
good luck
