There are many here way more knowledgeable about pure technical aspect of testing tubes, like curves, impedances and stuff. Something like
@moamps has done with vf14.
http://www.moxtone.com/mU47_U47_part3.html
But i'd do something like Thomas:
https://groupdiy.com/threads/microphonics-in-vf14-and-u47.82644/
Or coming up with some kind of simple testing jig to hit the tube at fixed velocity to excite ringing, and recording it.
And obligatory injection tests through fixed value capacitor matching capsule capacitance.
Different level sweeps using REW to capture frequency response, harmonic curve profiles and THD at those levels. Phase shift...
Recording some music through that cap, again different levels, different source material, both compressed and not compresed stuff. Maybe individual instruments captured with transparent mic, or even DI (piezzo steel string guitar - sharp transients). Pink noise!
You can then compare alternative tubes, and even do null tests, judge if your ear/head combo plays tricks on you.
I'm hesitant to say record some material through speaker under strictly controlled conditions simply because humidity, placement, and temperature are variables that can swing results considerably.
Noise shouldn't be that much of a deal to figure out, as tube mics are somewhat noisy so just recording constant low spl klick at fixed position and comparing should do it. I'm not obsessed with tube noise as long as it's at reasonably low level, I don't reach for tube mics if the noise might be an issue anyways. But that's me. I am primarily keyboarist, I love synths, we have a knob for noise, and it is sometimes even desirable. But that's another topic.
Ideally you would need several original tubes, just to see how much they vary between specimens, so you don't get hung up on one aspect that could be specific to that one tube. Or capsule, transformer, capacitor...
For anyone not believing all of this would be sufficient to bring you close to the target, i'm afraid the original would be the only alternative. Of course i might have missed something.
