G
Guest
Guest
[quote author="Martin B. Kantola"]
Will read the whole thread again, but Wavebourn, what do you think is wrong with the Schoeps circuit? (sorry if the question has been asked...) EDIT: If you can, please reply in terms of how it affects sound (which is far easier for me to understand)
Mikes are for listening to, yes? ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[/quote]
Once again: harsh sound that got the nickname "Broken Glass". The whole project started in attempt to investigate the cause of that famous "Chinese Harsh Sound" and eliminate the effect. There was a strong opinion of self-appointed Gurus who taught us that the "harshness" belongs to capsules. My investigation revealed that it is not: the capsule itself makes a peak on 9.5 kHz while the electronics distorts the sound. Highs intermodulate with fundamentals on pn-junctions of emitter followers causing the phenomena.
In my design the amp itself is very clean in respect to psycho-acoustical cleanness, also it is loaded on high impedance of the primary of the transformer; a peak is equalized by a simple RC network with 6 dB/oct slope. I know that LC equalization would be better, but have no appropriate acoustical measurement equipment needed for such precise work.
When I mean "Equalize inside of the mic" I don't mean to squeeze into the mic body the whole famous rack mount EQ with many opamps, input/output transformers, whistles abd bells...
No, I mean to build the mic amp and treat a mic body such a way so the frequency response will be equalized.
By the way, in best German microphones such equalization always presented: properly selected transformers, resistors, capacitors, even Miller effect in tubes was utilized properly, no complex EQ networks are visible on schematics', tha's why you may think that it is easy to borrow a capsule from one mic, body from the second mic, and electronics from the third one. No, no and no! Without understanding of what's going on it is impossible to get good results by simple combination of "borrowed"! However, with understanding such "borrowing" is not needed: it is always easier and better to optimize the whole system than try to glue parts that were not developed for each other.
Did I answer your question?
[/quote]
