The first comp I made was a modified LA-2A and I used the art work from that schematic as a template for everything else I made. I quite like re-drawing them neatly in Paint, it helps me understand what's going on and is part of the research I do for each project.
Most of my projects should be searchable on the forum, usually starting "x...........x from scratch".
I was a little disappointed by the R47, it seemed kind of dried up and lifeless, if that makes sense? After I finished it, I started reading up about non-feedback amps and the way the harmonics get treated under feedback. The R47 has a hell of a lot of feedback and it gives it a great spec, but I am not convinced about the sound, so I converted it to the EL84 amp.
Most of the classic pre-war amps did not use feedback, or very little, say 6dB, but the records made in the late forties and fifties using those amps sound great. I prefer my triode wired EL84 amp, it probably has a few percent of 2nd harmonics but that does no harm, a 12 string guitar is a six string with built in 2nd harmonics and no-one complains about that.
best
