A Fender Deluxe at moderate volume with a U67 two feet in front of it into your average 40-45dB tube preamp can require 30+dB of pad, so it's a legitimate question to wonder what you're doing when you toss all the gain the preamp is providing, so you can use the preamp.
Yes the scheme in that message should work. All the alternatives you have mentioned starting with the one in post #1 should work and they do work on transformer outputs without problems. The fact that you have distortion which depends on the setting of the control leads me to believe there is something else wrong with your preamp.Well, yes, you explain logically, it's hard to disagree with you!
I already have an input pad, but for more versatility, I still want to add a small adjustable attenuator (10dB) to the output, like in Chandler.
Can you please tell me if the scheme (message 49) that I tried to "peep" from the photographs can be suitable for this purpose?
True, I did not succeed in "peeping" the value resistors and the capacitor ..
