Strawtles said:Hi Ian, any news about this fantastic project?
Squeezing it in between the EZTube MIxer, the universal EQ and switch PCBs for the same!!
ruffrecords said:I have done some simulations of the new design which confirms the brilliance boost and cut Q can be made the same and I have worked out an initial set of capacitor and inductor values. It looks like the brilliance boost can be done with a VTB9044 inductor but there seems to be no standard one that will do the brilliance cut. This needs values of 10, 20, 32 and 40mH. Looks like on for Chrion.
I also discovered an error in the bass cut circuit which I have fixed hopefully. Pic of simulation circuit with notes attached.
Dylan W said:ruffrecords said:I have done some simulations of the new design which confirms the brilliance boost and cut Q can be made the same and I have worked out an initial set of capacitor and inductor values. It looks like the brilliance boost can be done with a VTB9044 inductor but there seems to be no standard one that will do the brilliance cut. This needs values of 10, 20, 32 and 40mH. Looks like on for Chrion.
Glad to see this is coming along. How sharp did you decide to go for the brilliance Q in general?
Dylan
Fablab said:Hi Ian, any progress?
buildafriend said:oh man, my orange 86 project just got cooler.
ruffrecords said:I can't seem to find a schematic for the orange 86.
buildafriend said:my assumption was that I could throw this post output transformer as a passive second stage within the same chassis. if you dont mind my asking, was the redd47 eq implimented differently than the way I am imagining?
ruffrecords said:buildafriend said:my assumption was that I could throw this post output transformer as a passive second stage within the same chassis. if you dont mind my asking, was the redd47 eq implimented differently than the way I am imagining?
The REDD47 EQ was implemented exactly as you imagine but it does have an insertion loss which was often made up by following it with another REDD47. Also it was 200 ohms balanced in and out.
My version is like the Helios and Pultec EQs I designed earlier in that it is intended for a 10K bridging input and needs to be followed by a dedicated gain make up amplifier. If you wanted it to be an 100% passive, no gain make up, 600 in, 600 out equaliser then that could be done by adjusting the component values but it would have about 15dB insertion loss.
