I have now tweaked a couple of resistor values in the brilliance cut and the cut now reaches 10dB (it is a little more at 10KHz because of the lower total series resistance due to the inductors). Also, the EQ was designed to be fed from a 10K fader in the EZTubeMixer and so was designed with a 2.5K source resistance. When this resistance is added in series with the input the boost hits 10dB on the nose too. So I am now happy with the response. If you omit this resistance the boosts are increased by a dB and are slightly sharper which is much the same as what is reported to happen in the real thing. Next step is to fix the PCB layout. In the meantime I might pass some music through it to see what it sounds like.
