dirty1_1garry said:Done some new measurements. Check it out on flickr.
http://www.flickr.com/photos/95158972@N07/
0.775V in
169 VDC - gnd/b+
154 VDC - gnd/pry wire
2.25 VAC - b+/pry wire min pot
13 VAC - b+/pry wire max pot
0.015 VAC - secondary min pot (connected to the circuit)
2.9 VAC - secondary max pot (connected to the circuit)
4.25 VAC - secondary (disconnected from the circuit)
15.6 VAC - b+/pry wire ( secondary disconnected from the circuit)
Voltage on the 220R = 1.84V DC
That makes more sense - virtually no output with the pot at min.
Open circuit output of 4.25V rms. 1K loaded output of 2.9V rms which means there must be 4.25-2.9 = 1.35 V rms across the secondary output impedance which in turn means the output impedance must look like 1K x 1.35/2.9 = 465 ohms. 15.6V rms on the primary with 4.25V rms open circuit on the secondary implies a turns ratio of 3.67:1 which in turn implies the plate circuit must look like a source impedance of about 6265 ohms
1.84V across 220 ohms means idle current is about 8.4mA which is also about right for this type of triode. Total idle current of 16.8mA drops 15 volts across transformer primary which means its dc resistance is about 890 ohms
1K reflected to primary is 13.5K. Stage gain is therefore mu x 13.5/(13.5+6.265+0.89) which is about 20 times or 26dB which is confirmed by 15.6Voutput from 0.775V rms input (26dB gain)
