There is a lot of information about what is best for the U47 : old stock uregulated NG PSU or modern, stabilized PSU. However, in different regions of Europe, there are different AC voltages: from 210 to 240 volts. I live in Moscow, and I often have to travel between different studios with my two U47s at work. In different regions of Moscow AC voltage ranges from 210 to 240 V. v Furthermore, the VF14's emission decreases over time and the internal resistance of mic increases . This results in B + voltage drop. Of course, you can constantly adjust the last RC filter in the NG PSU. But you must admit, is quite uncomfortable and unpleasant permanently solder the power supply. With the NG PSU I had a B+ voltage from 100 to 114 volts , depending on AC power. I purchased for these cases the modern PSU from A.Grosser . I found little difference in the sound and tried to understand what it is related to . I asked this question to many experts , but no one was able to answer this question. Finally, I realized what is this difference : the original NG PSU has more internal resistance than the modern, good stabilized PSU. Therefore, U47's dynamic behaves differently with regulated power supply. In general, the difference in sound can be described as : a good regulator improves the best attacks in full frequency range and better transients. Also, you have better overload capacity, impact on low frequencies and less distortion on loud sources. Share your thoughts and ideas about the causes of the difference in the sound. Maybe someone can explain it in another way?
