relay modules
salomonander
hey
i need to fit 5v controlled relays into my mixing desk channels. they will be controlled via a arduino system.
i have found a few products with vastly different price tags.
there are the expensive modules made by a company called pedalsync:
http://www.kaom.com/MV_57_Logic_Controlled_Relay_Bypass_Module_p/module_001.htm
im sure they are great. but not cheap at all. im wondering if a product like this would be any worse:
http://www.ebay.com/itm/New-1-Channel-5V-Relay-Module-Shield-for-Arduino-ARM-PIC-AVR-DSP-SRD-05VDC-SL-C-/280890946801?pt=LH_DefaultDomain_0&hash=item416667b4f1
..costs a fraction and does everything i need it to (i just need one pole). im just wondering if i have to watch out because of clicks or any audible downsides of the cheap modules. if there are none it would be a no-brainer and id go for the cheap versions.
thanks a lot
..or better even these boards for non smd:
http://www.ebay.com/itm/1-channel-Relay-module-5V-relay-extension-board-for-MCU-development-1pcs-/160863276260?pt=LH_DefaultDomain_0&hash=item257432cce4
Do you REALLY need to be switching 10 Amps of current?  Power relays have totally different contacts compared to low-level signal relays.
Bri
no. these will basically be audio mute switches. i dont know too much about the different forms of relays ...not really a tech. but i do need a low profile relay board that is triggered by 5v
i guess  this would be a better onet then (relay looks standard to me at least :)
http://www.ebay.co.uk/itm/DPDT-Signal-Relay-Module-24Vdc-TAKAMISAWA-RY24W-K-Relay-Has-Assembled-/130666441398?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D1281835936345345612%26pid%3D100015%26prg%3D1006%26rk%3D1%26
just dont know if it will fit in the modules. if anyone knows of anything smaller and affordable please let me know
After taking a quick look at one of the Arduino spec sheets, It looks like the digital outputs are rated for 40 mA, and thus can directly drive one of these:
http://www.mouser.com/ProductDetail/Panasonic-Electric-Works/TQ2-5V/?qs=sGAEpiMZZMs3UE%252bXNiFaVCLW1ZA8WQBLGF3Vwl4YaEE%3d
If the 40 mA drive spec is correct, all you'll need is to add a snubber diode across the relay coil, and then mount those two components onto a small piece of perf board.
Bri
thanks
yes. thats a good idea. problem is i need to mount the relay somehow. id need like a tiny relay breakout pcb (is there such a thing) with mounting holes or maybe i should look into relay sockets?
(Note:  the photo of the relay shown in the Mouser link I posted is apparently for a 4P relay.)
The 2 pole Panasonic relays are on standard DIP spacing, although a 10-pin DIP socket is not ultra-common, like an 8 or 14 pin.
Bri
Jacob,
Those boards are not really suitable. Check your PM.
Brian,
I would not dare to try to teach you how to suck eggs but driving relays directly from the output of a micro is not really a good idea.
However, Jacob has 24 to 32 channels of relay drive and it would not be practicle to drive them all directly.
I had noticed that the output port specs for several of the Arduino boards I glanced at claim they can source/sink 40 mA, while the little 5V panasonic relay is spec'ed for 28 mA current draw.  Perhaps if every output port was sourcing/sinking at once, the MPU chip will run too hot?  I dunno...never worked with an Arduino and ASSumed the output pins had some sort of internal buffering in order to meet the 40 mA spec.
Bri
Bri
Hello Brian,
Logic chips or basic transistors that can source relay-level current are typically made in a silicon geometry that's much larger than whats used for micro controllers.
Microcontroller, and other processors typically have their IO focussed on switching speed, rather than bulk current delivery.
In additional, microcontrollers don't normally take very well to the back EMF created by relays when they switch off.
I'm sure you could run the relay direct for a prototype, but I would be concerned with the reliability.
In addition, most micro's are moving to a 3v3 IO rail. I don't know of too many relays that take 3V3 as their switching voltage.
Rochey
Hi salomonander,
I use an arduino to control audio in my mixer project using fets and an optocoupler arrangement. have a look here if you are interested.
http://audiomixer.wordpress.com/2012/04/19/control
this post shows the control voltages for the mute switch, I have the mute switch arrangement somewhere..... just can't find it right now, based on a douglas self design....
basically its a click free mute / selection, no relays, dedicated control power supply....
cheers,
Michael
I did make several comments re. a "snubber" diode across the relay coil......that seems typical for any type of circuitry requiring a relay.
Perhaps I need to read a bit more about the chip used for the Arduino, since 40 mA source/sink current per pin does indeed seem FAR more than what a typical uP can provide.
The boards I was looking at are 5VDC powered, vs 3.whatever used in "modern" uP's.
Bri
I did some digging, and found this spec sheet from Atmel, the maker of various chips used for Arduino gizmos.
http://www.atmel.com/Images/doc2545.pdf
Goto (lol...Olde BASIC instruction code)  page 303 of the PDF, where I see the (in)famous 40 mA/pin  AND 200 mA for the entire package.  I ASSume the other uP chips used in Arduino apps have similar specs.
Sooooooooooooo.....even those little Panasonic relays that I mentioned will draw too much current if every one was sourcing/sinking current at the same time.
My goal/objective was to try to assist the OP in his quest for a KISS solution, and alas...some sort of buffer will be required to drive the relays.  I guess the relay buffers could be built onto a "shield card" (using the Arduino terminology), and then the spaghetti of wiring would go from there to the individual relays (with snubber diodes across the coils, close by each relay) within the audio device.
Bri
Steve,
I looked at those ones for my modules... At 500mW they are power hungry little puppies!
I used the omron g6k-2p, which are lower power (but more $$$).
I'm about to redesign the modules and wondered which you think I should choose?
