How would i go about controlling a pot from 100 ft away?
Ten 10-foot poles lashed together?
Use a bigger stone to kill more birds.
WHY do you want many amplifiers all over the stage? They need power. Batteries are a drag. Plug 'em in, now you have a lot of 200-foot ground loops between 120V power cords and low-level audio cables. And then you need fancy-tricks to kill the buzz and CB radio. And the small amps are custom-DIY or Banjo Centre junkboxes.
Get a bunch of 100W amps. Maybe your old monitor amps. Put them at FOH. Maybe they are already there.
Be sure they are Common Ground, because we are gonna tie all the black terminals togther. Put 1 ohm 10W resistors on all terminals to give something cheap to chew on when wires short. Feed each with an instrument or submix.
Each performer gets a box of 1K pots and 270 mix resistors and headphone jack. No electronics, no power except what comes in the audio signal.
One CAT5 cable will carry 7 signal wires and one common ground. Yes, unbalanced! Speaker wires don't collect crap, because the far end floats, the signal level is 20V, and the source impedance is 2 ohms.
7 signals might even be enough for a 3-man band. Bigger acts will use multiple CAT5 cables: a set of red green grey black CAT5 (24 signals total and two grounds in each cable) is far cheaper than any shielded pair snake.
I show daisy-chain, but for larger acts you should probably have a splitter (CAT5 punchdown panel and jumper links) so only a few performers are on each run.
