The reason I asked about whether the front diaphragm is at Ground in f8 is because it's also possible if you're supremely unlucky that the front wire was kinked against the lid in the box and during shipping exactly the right amount of internal strands could be severed leading to a front diaphragm that can be grounded but not polarized. You could also check the front lead wire for Sharp kinking damage at about the diameter of the capsule. My war against wire microphonics put me in a tough place. Neumann decided to use thick, mass and stiffness dampened wires. They can only make this decision because they make the entire microphone and thus have control over termination and can terminate the wire after a short distance in a way that doesn't really need flexibility. Since I don't have control over how the capsule is installed, I had to go with longer wires, which required different and more fragile insulation to keep microphonics down. It's one of the annoying things about selling retail and OEM capsules. I don't get to consider the system holistically.Ok, I’m happy and sad to report that the flat k47 in the other mic works correctly. I bet that the melted socket or some of the sloppy soldering is messing the 1st mic up. So, I’ll try wiring those pins to the circuit board directly and getting the socket out of there. I’m also going to check the joints on the extensions I soldered to the capsule wires on the first one, because I didn’t extend the wires on the second.
Worst case scenario is that I buy another mic and do it again. $70 for a learning experience isn’t so bad.
