CJ said:you could build a jig which represents the circuit in which the transistor is used,
Someone told one time "for Neve first stage transistor you need to select the BC184C for higher than 600 hfe" (no base current or voltage was specified) then somehow that spread around and now people think that you need to have BC184C transistors with hfe higher than 600 (again no base current specified) when Neve never selected BC184C transistors for gain.
Neve just used the transistors straight from the shelf, from the factory or from the local shop.
